1 - 19 of 19 Posts
Anyone out there in VTX land , have a set of Stock shocks sitting around ? Maybe taken off the bike barely used and put away and forgotten about. Don't have the cash to get a set of after market, so thought someone that did might have a set ?
Sent from my E6910 using Tapatalk
Smitty, what's the issue with you needing shocks, did you have 1 break or leak like I did? Hope you have better luck finding stock ones than I am waiting for my Progressives! My stockers are long gone, and my 1 MB won't do you any good. Sorry. Did you check on the VTXOA forum?
Yes I do have a set mine is a R model they have 12000 miles on them i went with air ride
I'm not sure Fran. I have a rattle and not feeling quite right. Just thought might be able to find a set with low miles and be ready when get into checking it out. I have read about how long you've been waiting, that's one of the reasons I'm not going that direction, well and cost.
Do you know if they are the same for each model ? Like a R fit a C .
Aftermarket shocks it says fits R-C-S-T not sure how true that is here is my phone number 1 (803) 415-6717 I can send you pictures if you interested
They should all be interchangeable except for the 1800F with that bearing built into the top mount.
Discussion Starter · #8 ·
Thank you. I'll get ahold of you.
Discussion Starter · #9 ·
Fran ,for some reason I can't post on the 1300 for sale on OA. Is there anyway you can post that for me ? I have the same screen name over there. Smitty8076
I'll try, buddy.
OK, I posted, and asked to PM you here, or use me as a go-between on the OA. Good luck, brother!
Discussion Starter · #12 ·
Thanks Fran. I just figured all the guys that put after market on ,would have them sitting around collecting dust. And would be wanting to part with them for cheap ?
2007 1300C
I have a set.
PM sent
Discussion Starter · #14 ·
Thanks Fran. Just bought a set.
Not sure why I can't post over there, I have before?
If you didn't already, you may want to order the green polyethene honda bushings. Some people like the Master Carr nylon bushings. I went with the green honda bushings
I believe these are the Honda bushings. I brought this ad to my local dealer, they price matched and had the parts to me within 1 business day (pre-covid). You can order 4 of them and use them in each eyelet.
Honda 52489-HN0-671 - BUSH, RUBBER (UPPER) | Partzilla.com
Master-Carr Nylon bushing:
Light Duty Dry-Running Nylon Sleeve Bearing, for 5/8" Shaft Diameter and 7/8" Housing ID, 3/4" Long | McMaster-Carr
Reactions: PaXman11
Look on EBay. Saw three sets out there for around $60
Discussion Starter · #18 ·
Thanks ,will probably get a set to be safe.
1 - 19 of 19 Posts
