Recently did some carb work using the Factory Pro Stage 3 kit, and got great advice from others on the Cafe. One topic that many people commented about was the difference between the stock and FP needle. Took this picture (hope resolution is OK) to show others the visual difference in the taper of each needle. Stock needle on the left, FP on the right. Note the notches in the FP needle, using the supplied clips you can adjust the height. Clip position #1 on the FP needle is the top one, working all the way down to a 5. The lower the clip, the higher the needle position. Hope this gives a good visual aid to others who will be swapping their needle in the future.
