I have a neighbor who should not have a motorcycle. He has dropped it three or four times, because he is only about as tall as “Mickey Rooney”. I won’t go into his other shortcomings; dent in tank, bent & scratched left rear view mirror, damaged left handle grip, bent left foot peg, scraped paint down to the metal on rear left swing arm, etc…
He purchased 2010 Honda 1300CS Sabre back in February at the local stealer. Walked in said I want that one, they fixed him up $12,559.00. (I know they saw him coming)
I ordered him some ISO grips, and a set of Cobra Fatty engine guards and install them for him.
Then I offered to help him out and replace both the broken left turn signals front and back, damaged during one of his drops.
Has anyone ever replaced one of the OEM turn signal assemblies?
The new one has two wires coming out of the stem with a quick connect on the end.
The OEM parts image shows a machine screw that goes into the stem from behind an ABS plastic molded part that mounts under the rear fender.
Looking under the fender I can see a screw that looks like 8mm bolt, but cannot see where the connector for the wires is. I suspect it goes under the molded plastic part that holds the taillight and licenses plate.
(I know the Forum police are going to chastise me for posting here, so just wanted to let you know I posted it over there also.)
Need your input, how-to or suggestions.
