Hello from Houston,
I have had some recent issues with my 2006 VTX1300C. I got sick and ended up doing what I said I would never do. The bike has sat up in my garage for more than a year. Aside from this blunder which is completely my fault, I have not been able to get the bike running. I have "hired" several people from nextdoor dot com, but none of them were able to get the bike going again. Here is what I can tell you:
1. The old gas was discarded and new gas used.
2. The carburetor was rebuilt using an All Balls Rebuild Kit.
3. Gas tank hoses replaced as was the battery.
You have to spray the carberator with cleaner to get it started. The bike will run as long as you continue to rev it up or keep spraying. The minute you get back to regular idle, it dies. I have not taken a look at it again in about a month. With the situation as it is, my first thought was the gas tank hoses since it seems as if gas is not getting to the carb. These were replaced, but the problem persists. I am not sure what else to do. It sounds like something simple, but I am not sure what that might be. Not now at least.
I would greatly appreciate any advice. Thanks in advance for taking the time.
Eric
Eric
