Been riding for 14 years and have had 4 flats in all that time. 1 about 8 years ago and threee in the past two weeks
1. Two weeks ago came out to a flat. Took the tire off and went to a mc tire shop. Had a small diameter nail. I have the S so they replaced the tube.
2.This week I go on a mc camping trip. Wake up Thursday morning to a flat. Thankfully I found a shop that said they could get me in. I added air, rode it 7 miles to the shop, nervous all the way. When I got to the shop the tire was still inflated. He checked the valve stem first. It was tight with no apparent leaks. He found a small chunk of metal in the tire but said it barely penetrated the inside and was surprised it caused my flat. Installed a new tube.
3.Tire was fine yesterday morning. I packed up and headed home. This morning I go out to clean the bike up and the rear tire is flat again. I put it in my jack, aired up the tire and inspected with soapy water. I can’t find a leak anywhere.
My issues and suspicions:
1. The tire only goes flat when sitting over night on the side stand.
2. I suspect the second flat wasn’t due to the metal chunk. I suspect the 90 degree chrome stem has an issue that only presents when left on the side stand over night.
I think it screws on to the tube stem and mounts from the inside of the wheel. So $280 later I am considering trying to fix this myself.
How hard is it to break the bead on a vtx rear tire? When I had a Vstar 650 I used to change my own tires. When I owned a Goldwing I tried one time and gave up. How does the X compare?
Have any of you ever heard of the 90 degree metal stem going bad but only leaking intermittently?
I appreciate any advice. I would love to avoid shelling out more money.
