Best to stick with other 1300 VTX rims. They will fit.
Harley can fit with an adapter from Goheen.
VTX 1300 HD Front Wheel Adapter Kit | goheencycles
Wanna be able to run a fat spoke or other aftermarket Harley Davidson wheel on the front of your VTX? This is exactly what you need! This adapter allow you to bolt your factory rotor right on a HD wheel with a hub diameter of 101.9MM (4") which is most aftermarket front wheels. To make this...www.goheencycles.com
I guess I should have been more specific, although that does help some when I get ready to do the front, I am currently needing info about the back tire and wheel!Best to stick with other 1300 VTX rims. They will fit.
