Hello everybody, I have a 2002 VTX1800c. I've quite bit on the lights here and other forums. I have all LEDs on the turn signal and a flasher installed.
Rear Left turn signal doesn't blink and front left is out. I just got replacement ones today. While troubleshooting I found the Blue wire coming out of an Orange box that is not sending the flash signal or brake, just stays on. Blue wire converts to orange that leads to the left turn signal. Looks accurate to the wiring diagram. The turn signal does light on the cluster.
Does anyone know what the orange box is called or part number? I'm suspecting this to be to culprit as of right now.
Right turn signal does flash but makes both the left and right flash. I've read that I need to install a diode resistor to prevent flood back current. Oddly enough, the turn signal indicator doesn't turn on if I use the right side. Not sure what that could be yet.
