1 - 6 of 6 Posts
Guys,
Can anyone tell me where the turn signal relay is located on my 03 VTX 1300 and if its something that I can change myself? Thanks in advance!!!!
This is the Honda part # 018 RELAY, TURN SIGNAL (DENSO) 38301-MBW-D21
Should be under the right side cover. The one in rubber with the plug in the "back" is the fuel relay the other one has a plug srait in the bottom, thats the one for the blinkers.
Before you buy a onda replacement, check into the electromechanical replacements.
they are available at a number of places like:
www.customled.com
or
for a good right up check this out.
http://tech.bareasschoppers.com/electrical/replacement-flasher/
The advantage is that if you every change to LED lights you won't have a flasher issue that comes from the load change from the LEDs vs regular turnsignals.
1 - 6 of 6 Posts
