1 - 20 of 26 Posts
:banghead: I do not know if there has been a thread posted about this or not.
The X is my 1st bike & I love it. One thing I have noticed that I forget to do once and awhile is to shut off the turn signal which is kind of embrassing & not a very safe thing to do while in traffic. So here is my question. Has anyone figured out how to get a self cancelling turn signal? Possibly some sort of a mercury switch mounted on the steering head cut in line? Any thoughts? :confused:
There are signal minders and self canceling fixes out there, or just get in a habit of canceling them.
There are units out there that can self-cancel, Kuryakyn makes one, a simple beeper is available at www.glensvtxgarage.com
I forget mine all the time, and it isn't safe, especially in traffic.
Happy modding!
I think most of us forget them at times, i know i still do. I dont forget them as much, but it was downright embarassing and of course, not safe when i first got my x..there are kits to buy as a previous poster said. Good luck with your bike!
Bry:choppersm
Re-member
I got a beeper for mine... inexpensive, easy install, and I don't forget to turn them off anymore.
I've got a beeper from Glen that you can have if you want it. It works fine, I just got tired of sounding like a dump truck backing up. But if you want it, it's yours. PM me your address.
I took it off when I got the Kisan unit. It has some behavior that I don't like, but IMO it's the best thing available.
Ride Safe:choppersm
Equito Passim
Donut here makes a Turn Signal Beeper you can put in your headlight bucket.
Beeps when your signal is on.. Gets annoying, to be honest.. but its a constant reminder..
-Gonz
Discussion Starter #10
Guys thank You for the advice. As usual you guys are great!:patriot:
DKilleen PM sent & Thanks Bud!
Senior Member
I installed a beeper on mine that silences when you apply the brakes. Someone on this board posted a way to wire it that way, it's been awhile and don't remember who or when. Maybe a search will find the thread for it. I like it because if you're at a light or stop sign you don't have to sit there listening to it beep as long as you have a brake applied.
:choppersm
Re-member
-Gonz
That's who I got mine from...:mosh:
:choppersm
:hmm2:Sounds like a good mod to make to the beeper mod...it does get annoying sitting at a light!
One other option that I never had on any of my other bikes that took me a while to notice.
When canceling the signal you don't have to go from L or R to center with the button, you can just push in the button from that position and it cancels the signal.
(I'm sure most here know this about their X but some newer owners might not)
Favorite Bike - V65 Magna
:choppersm
That's the way my Radio Shack piezo buzzers are installed. The black wires are connected to the brake lamp wire. It not only silences the beep when the brake is applied, it also warns if the brake lamp is burned out. If the brake lamp circuit is open (burned out), the turn signal alarm will not sound when it normally should. The system also alerted me to my rear brake switch being out of adjustment. It's a good mod.
I did a write up on the subject a while back: Turn Signal Buzzers Are Better Than Timeout Modules
http://www.vtxcafe.com/showthread.php?t=29881
Geezer
Got one of Glen's turn signal beepers here....Pre-wired, excelent instructions, just plug in and go...Was a bit too loud, but a piece of black electrical tape covering part of the opening cured that...
BTW...Glen's is setup to be silent when the brake is applied...
Louisiana Swamp Rider
I installed a couple of Radio Shack piezo buzzers under the right side cover, $4.49 each.
Geezer
I used this method also before I installed the fairing and it worked great.
After the fairing, I installed to LED buttons, one on each side of the radio, which flash a 'bright' amber light in my eyes. Day or night, I no longer leave my turn signal flashing. I simply tapped into the turn signals in the headlight bucket and ran the wires up to the fairing. Total cost under $10.
I just got my leds the other day to do the same thing. I got the 2" chrome strips and am going to mount them to the windshield.
'Chappy'
I did a write up a while back with some new variations.
http://vtxcafe.com/showthread.php?t=41621
and gleaned a few tips from the VTX tips site
http://vtx1300tips.com/TurnSignalbeeper.htm
and what I ended up with on my most recent project was a bright LED and a piezo beeper. in a very small compact experimenter box. three wires down to the headlight bucket. two diodes a buzzer 1 - 12v LED and a small on off switch to turn the beeper on and off when I am running my four way flashers.
sidenote: four ways are great and easy to add. I did a write up on that one as well
http://vtxcafe.com/showthread.php?t=46140
The result ended up that when I am not paying attention to the bright white light, that the beeper would catch my attention. sometimes especially in groups, I am paying more attention to traffic around me than I am to what is blinking below me, so the beeper works well
I did end up using a small molex connector on the three wires coming from the headlight bucket, so that i could leave the LED box mounted to either the fairing or windshield and just unplug when I wanted to remove either one. that and if I come up with any other options, I can unplug and plug without having to mess with the headlight bucket.
Discussion Starter #20
As usual you guys are the best. I love this site no one makes you feel like a dope for asking a question. You ask a question and everyone pitches in some real common sense input and practical experience. I thank you all for the help and have glens beeper on the way from Dkill. The Cafe and its members are top notch in my book.
:choppersm
1 - 20 of 26 Posts
