I was taking the bulb off my front turn signal To see what kind of bulb I have to change to LED's I put it back together and now I've noticed that my Blinker is blinking faster than the other side Did I put the balden backwards 2nd question the rear turn signals on my bike is off and only turns on when I use my turn signals Did I screw that up too or does it stay off Till I use my turn signal
It is difficult but not impossible to put the bulb back in 180° out of proper rotation. Check for this.
Look closely at the bulbs. Looking at the bottom of the bulb, normally pins would be opposite each other, like at 12 oclock and 6 oclock, but sometimes....they are at 12 oclock and 5 oclock, and if you look at the sides of the brass the pins are not at the same level.
Reactions: vtx-1300
