Viking Saddle Bags Installation
4669 Views 9 Replies 7 Participants Last post by  AlanSmith7
2
Hello Friends,
I just purchased a set of Viking Single Strap Shock Cutout Slanted Large Motorcycle Saddlebags for my 2007 VTX 1800F. However, I am having a lot of difficulties getting them installed and wanted to see if anyone has solved the riddle. I have a backrest and sissy bar combo which I believe covering up the normal installation bolts.
I attempted to follow the instructions for the installation using the FAT Brackets, however, it appears those are not appropriate for my model bike and the bags I ordered. With the shock cutout, the front fender bolt missed any part of the bag that can be drilled into. Similarly in the event, I was able to squeeze a hole in that location, the bottom of the FAT bracket would having nothing to be mounted on. I, therefore, assume that the “throw-over” installation is the only one appropriate for the combination of the bag configuration and motorcycle model.
HELP !!!
Electronics Electronic device Technology Electronic component
Vehicle Automotive tire Auto part Tire Motor vehicle
See less See more
1 - 10 of 10 Posts
Forgot to add that I am new to the forum and this is my first post :cool:
Hey, I’m having the same problem. Did you figure out how to get those Viking bags on your bike?
4
I ended up buying a Cobra backrest & sissybar combo with rack so I could mount them. I still had to mount the forward mount at an angle to clear the shock cutout. Filing the toss-over strap in case I have any problems with the FAT brackets. FYI - I did have them send me the other set of mounting brackets and it was the same problem.
The kit that they sent to install them as "toss-over" had instructions that instruct you to drill holes in your bags and attach them to your bags, their bags are nice but their instructions really suck. If you do decide to do the "toss-over" you will still need a bracket behind the bags to keep them in place, per the original instruction, and there is a strap on the bottom of the bags to secure the bags to the brackets.
241258
This is what's in the hardwarekit, you'll still need the bolts from the original installation kit
241259
This is the hardware kit that you can request from Viking
241260
241261
This is installed with the FAT bracket.
Good luck,
See less See more
I mounted mine using the supplied brackets, but drilled and tapped a hole in the backrest mount where the rear bolt for the fender is (hidden under the backrest mount).
241274
Then used a nut on the backside as a jam nut. Only issue is that in order to remove the bags, I have to remove the whole backrest assembly. However, that is a rare occurrence.
See less See more
I have also installed Viking on my motorcycle and my friend helps me with installation, for make it removable you can install their quick disconnect.
I looked at doing that, but the reality of it for me is that I generally don't remove my bags. These are locking, and I have the lock tab removed off of the left bag, as I use it for quick access to and from work. On longer trips, I reinstall the lock tab and lock them down. I have found that once you get used to having the bags, it is hard to go back to not having them and wearing a back pack...
I can see where quick release would be useful.
Ride Safe!
Reactions: 1
Hi, first time on this board. I have the exact same bike as you! So, nice bike. Anyhow, I'm looking into getting saddle bags but Viking is telling me that if I put them on, passengers will have a difficult time riding. Is that true?
The kit that they sent to install them as "toss-over" had instructions that instruct you to drill holes in your bags and attach them to your bags, their bags are nice but their instructions really suck. If you do decide to do the "toss-over" you will still need a bracket behind the bags to keep them in place, per the original instruction, and there is a strap on the bottom of the bags to secure the bags to the brackets. View attachment 241258
View attachment 241260 View attachment 241261
Good luck,
Oh , yes, the Viking bags blues. I about put bullet holes in them when I put mine on. What a bitch! I have the N model and that made it a bit easier since the fender bolts were already there. I, just by chance, already had the Cobra back rest and luggage rack. I have had to get longer bolts from Lowes to get the job finished. Then I noticed that the bags were a bit too small. What did I do about it? I live with it. I am NOT going through that hell again lol
1 - 10 of 10 Posts
