That thing on the right side of the engine for an air intake is a Hypercharger. Fancy name, doesn't do jack sh## as far as any performance gains. Strictly there for a certain LOOK. And it gets in the way of your leg. Stock Iridium plugs on a VTX are good for 100,000 mi. Use a mirror tool to inspect the inside of the tank. If really rusty, it will need drained, cleaned either by an abrasive or chemical solution, re-sealed against further rust. ALL fluids are hygroscopic meaning they draw moisture, should be changed every 2-3 years for optimal performance. Rear 'final' drive oil should be changed too, and as most of us get less than or around 8-10K out of rear tires, when the tire is changed is a good time to clean the final drive splines and re-coat with MOLY paste, -not- grease! A little goes a long way. Not real easy to find, but Loctite makes some. Fork oil is usually the last fluid to get changed, usually when new springs are being installed. Replace the shock bushings with the Honda GREEN bushings. A little search will find the P/N. Inspect the disc pads. If they look real thin or scored, think about replacing them, and use OEM Honda for best performance. Don't go cheap, you will be sorry in the long run. Cheap pads squeal, make tons of brake dust, wear much faster, and eat rotors. A few things you can consider: When changing your tires, going to steel 90* valve stems. Using 'Ride-On' internal gel tire balancer and sealer. Insurance in a bottle. Replacing ALL your fuses with the EZ-ID or Smart-glo kind that light up when they pop, makes troubleshooting a problem so much easier when you can eliminate all but the offending circuit. Consider upgrading all lights. The 1157 brake bulbs can be changed to 2357, a bit brighter. VTX Daymaker is a very good headlight swap. They offer a bunch of brightness & colored halo options. Don't waste $ on running HI-TEST fuel. These engines were designed to be run on 87 octane for best performance. Run 38-40 psi in the tires, and adjust to preference up/ down from there. Some things printed in the owners manual just haven't proven to be the best! There are a bunch of us here every day to answer any questions. Where are you located? Welcome from central Pa. high atop the Alleghenies.
