The owner's manual states 87 octane or above.
You are correct that most bikes have high compression engines and therefore require high octane. The VTX has a low compression engine and performs best with low octane fuel.
Octane is not a measurement of power, it's a measurement of resistant to predetonation. When fuel and air is compressed inside your cylinders, it generates heat and could combust before the spark plug fires - which is predetonation. Octane is added to gasoline to prevent this issue, needing higher octane levels for higher compression pressures.
If you run high octane gasoline in a low compression engine, you risk the fuel not burning completely and efficiently, possibly gumming up the system or even fouling plugs. Note that I said "risk", not absolute result. That contributes to the number of people that oppose this view and they reply "I've been doing it for years".
So that's the explanation. Run regular gas and your VTX will be happier (plus you save money).
Please feel free to research this stuff via engineering and science sources, avoiding the personal opinion sources. Everyone's an expert in their own mind. Discovering the truth on your own is the best bet.
