I've decided I now want to add a 30 amp relay between the battery and my existing "jconrad" power distribution block mod using a trigger from the blue/white stripe wire inside the headlight bucket. I found a blue/white stripe wire that is connected on both sides of the red connector, (see attached photo). Does it matter which side of the red connector I splice my tigger wire to?
Also, exactly what is the best way to splice into this blue/white stripe wire? Is it ok to use one of those 3M Quick Connect (snap on) splicers? Or, is it better to simply cut the blue/white strip wire, strip the ends, and then solder or wire nut my trigger wire to those ends?
Also, is it ok to use an 18 GA trigger wire from the blue/white stripe wire to the 30 amp relay?
I've searched the power distribution block mod threads and could not find exactly where and how others have tapped into this blue/white stripe wire. Any advice from those that are experienced with this mod would be appreciated!
