mz25
1 Read this.
I don’t know why but it seems that a lot of bikes run fine when
new but after a couple years they seem to start having trouble.
Ok some may be able to get away with using the choke but that
may have to do with when the set the carb during assembly.
However most of the time when someone is having trouble
starting their bikes it is usually due to using the
choke/enhancer and fouling the plugs. The choke in these bikes
isn't like the old fashion butterfly you are use to on older
types engines. The choke/enhancer actually dumps a whole lot of
gas directly into the cylinder and fouling the plugs. This is
all caused by the manufacture setting the A/F lean (1 5/8)
turns open to be able to pass EPA standards. If you set the A/f
at 2.5 turns open - most of the time you will not even need to
use the choke even when it is cold out.
Hers a link;
Glen's VTX Garage
I'd order the permanent a/f
Donut
atriot
oug
