I am installing a Howards Horn on my 2002 1800C
The hot wire that I thought was wired thru a light / key switch fryed its way to the battery when I let it touch ground. The hot wire going to the input (30/51) to the horn relay was wired directly to the battery with no fuse. I am definitely not an electrician but the Cylmer wiring diagram shows the hot wire should be going to a juction but it does not clearly indicate where that junction is. Maybe the hot to the turn signal switch. I need little help to know where to run the hot wire to avoid another meltdown mental and physical.
Thanks for you consideration
