If you are not running a relay you will burn up the starter switch, so the answer is no it is not ok.OK, well, as stated, it seems to have been the "factory wiring is too small." I got a fused line with larger wiring, and placed the same size fuse in said holder, and all is just as it should have been from the beginning. THANK YOU ALL SO VERY MUCH for your kind help in this issue!!!!!!!!!!! Do I need to turn them off to start the bike? I know in the winter it may help to turn them off so there is one less thing draining the battery when I'm trying to get it to start, but when the weather is warmer, does it hurt anything to leave them on?
