I know its standard maintenance at a certain mileage. But aside from that how would I know when to its necassary? My bike has been acting funny and for the life of me I cannot figure out what is wrong. I doubt the valve adjustments were done on time before I bought the bike. Im trying to figure out what symptoms the bike would display of needing to be adjusted.
Also any other ideas on what is wrong would be helpful.
Here are the symptoms
- Bike runs perfect some days and some days it acts up.
- When it acts up it does if feels like it runs rough but it idles fine.
- It drives normal mostly it just feels and sounds like the engine is bogged down and out of sync when moving but fine when idling.
- It feels like the gear range is shortened like I have to shift earlier then normal. ie I normally shift to 3rd at 50, when it acts up I have to at 40.
- The gear range also feels shorter on the other end. ie if I downshift it feels like its bogging down.
- Checked oil, changed oil.
- Checked vacuum lines.
- Checked exhaust header is tight.
- New Spark Plugs.
- Cleaned engine with seafoam through vacuum hose and in gas.
- Dont feel any slipping but the clutch does have high miles.
- The battery is old but it starts fine, and since its carb I didnt think that could be it.
