light bar switch problem
1 reading
715 views 2 replies 3 participants last post by  Cruiser1
#1 ·
I'm having trouble with my light bar switch,I just replaced it say 6 months ago. I was riding home tonight and turned it off and that was it, wont come back, its pressed in. so now i'm wanting to remove the switch and just connect the wire and run my honda lightbar I don't ever turn them off any way. will this cause trouble with things electrically.?
#2 ·
It will cause no more problem than the current set-up. What matters is whether or not you run the light bar through a relay not whether the lightbar wire has a switch. You should be running the lightbar power through a relay to take some of the load off the circuit running through your starter button.
G'day,
Vinish
#3 ·
My switch quit on me, so I went to Napa and bought a sealed toggle and put it in the place of the original, it works good.
