Sunday, while out riding, the temp light came on. Stopped and checked antifreezee and found the belly tank empty. Looked underneath and found it dripping from underneath. Got a chance today to remove the side plate and check hoses. All hoses tight, then saw the fluid dripping from underneath the water pump. The manual says to replace the whole pump if fluid leaking from bottom of pump. Found that the parts list shows the gasket and O rings available. Any problems with replacing these? Bike had sat for 18 months after my accident in AUg of 2009. SO far the rebuild goes well.
