Well I hardly know anything about mechanics but I am trying to teach myself.
Anyhow I came here to verify the process for the switching of spark plugs. Want to make sure I have it down right before I go touching anything. Dont want to strip something. I found the manual and just wanted to overview it.
Basically I take off the covers around the cylinders and located the spark plugs. After finding spark plugs I blow the area around the plug and make sure there is no debris.
Once I loosen that hose the spark plug is located on the inside correct?
After I find the spark plug I carefully extract the plug from the hose and prepare to place new plug.
I saw online a guy recommended that to thread on a spark plug you, hold the hold the hose above the threads and start off by threading the hose around the plug rather then doing the plug into the hose. He said it prevents from cross threading the plug.
Last but least I tighten with spark plug wrench. Can I get the wrench from auto zone? and is it any different then other wrenches?
Now for the shopping part:
DCPR6E (NGK) XU20EPR-U (DENSO) - Standard Spark Plug
DCPR7E (NGK) XU22EPR-U (DENSO) - Extended High Speed Riding Spark Plug
SPARK PLUG GAP: 0.8 – 0.9 mm (0.031 – 0.035 in)
Any recommendation and what I should look for when shopping for the spark plug? Ill try to stop by Auto Zone and look at the box and see where the info is.
Dad never taught me anything about mechanics, so I know the majority of this sounds pretty damn easy and I am probably over complicating the situation. I just bought this bike used and want to make sure that it is in great condition and I dont screw anything up. Just trying to research all I can before I mess with anything.
Thanks Again, Sorry for the Essay
- SYRUS
p.s. I talked to the original owner and he said he hadn't switched out the plugs for almost 7k to 9k miles.
