how many turns out should the idle adjustment screw be? i dont know if my idle is too high or not?
Below the breather right side.I have the same issue with my C starting in the very cold weather. It starts very rough and will sometimes die. You can't use the throttle or cruise control since that immediately kills the engine.
Above the breather there are two knobs, one the idle set (?) and the other has a crimped metal band (?)
I turned the non metal banded in until it set and turned back two full turns out but I think it went in more than two full turns (hard to tell when it only turns about a quarter of the time. Given my aforementioned cold starting problem, how does this make sense and what did I do???
Pardon me if I missed something along the way as I haven't caught up on the whole thread.I turned the non metal banded in until it set and turned back two full turns out but I think it went in more than two full turns (hard to tell when it only turns about a quarter of the time. Given my aforementioned cold starting problem, how does this make sense and what did I do???
900 rpm +/- 100 video from Gonzo
http://s1000.photobucket.com/albums/af122/Gonzo1970_bucket/Tuning/?action=view¤t=tune002.mp4
I am on base.LBell
Are you on the base or in North Edwards? I'm in Cal city on the weekends most of the time...not going home this weekend. Willing to give you a hand on you bike if you need it. To adjust the stock air fuel screw you will need a 223 case or 22 case with a flat spot in it (like a D) there is not a slot like a normal screw.
